Updated: Dec 8, 2023—3 min read
New ZY-M100 mmWave Radar Sensor with USB type C in Home Assistant
OverviewHow to integrate it in Home AssistantEnable New Variants Full ZHA SupportRecommended Starting SettingsIlluminance Sensor fixBlueprintRelated Sources
Sensor
Blueprint
Sensor
Blueprint
Sensor
Blueprint
ZY-M100
Incredibly affordable MMWave Radar Sensor with almost instant presence reaction time. It also opens up the opportunity to extend your Zigbee network by serving as an additional router 🎉🎉🎉.
Overview
  • ZY-M100 Mmwave Radar Sensor
    • Amazon: (microUSB)
    • Aliexpress: (type-C)
  • Holder Stand Adjustable:
    Zy-m100 Stand
    • Aliexpress: (here)
  • Stand to 3D-print:
    Zy-m100 Stand
    • Printables: (here)
Open your Home Assistant instance and add a Zigbee device to your instance.
You can use this button to be redirected to you Home Assistant instance to add the device to your Zigbee network.
First create folder custom_zha_quirks, then create file ts0601_radar.py and paste the code from the supported variant that you need.
If you need more than one variant, you can create multiple files with different names.
List of supported variants
  - _TZE200_ar0slwnd
  - _TZE200_sfiy5tfs
  - _TZE200_mrf6vtua
  - _TZE200_ztc6ggyl
  - _TZE204_ztc6ggyl
  - _TZE204_sxm7l9xa
  - _TZE204_qasjif9e   #new
You can find the code here
Configuration sliders in miliseconds, 1 second = 1000 miliseconds.
  - _TZE204_e5m9c5hl  #new
  - _TZE204_ijxvkhd0  #new
Configuration sliders in seconds.
  - _TZE204_yensya2c  #new
Then you can add this to your configuration.yaml file.
homeassistant/configuration.yaml
zha:
  custom_quirks_path: /config/custom_zha_quirks/
Recommended Settings
Fading time:
BELOW 65000 miliseconds (-65 sec): The unit only detects large / faster motion, ignoring micro motions.
ABOVE 65000 miliseconds (+65 sec): It detects micro motions in the central cone, like breathing etc.
Light Sensor fix
Via Reddit
Blueprint
💡𐂷 Sensor Light
By Blacky
Documentation here
Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint pre-filled.
Related Sources
You can find more information about the ZY-M100 sensor in the following links:
  • https://github.com/zigpy/zha-device-handlers/pull/2525
  • https://github.com/zigpy/zha-device-handlers/issues/2378
  • https://github.com/Koenkk/zigbee2mqtt/issues/17483
