Updated: Feb 19, 2025—3 min read
Coral AI Person Detection with Home Assistant & Frigate
PrerequisitesFrigate Full Access Add-OnFrigate IntegrationAdvanced Camera CardMosquitto Broker Add-OnConfigurationAdvanced Camera ExampleMobile Notifications Blueprint
Blueprint
Coral TPU Acelerator
  • Coral TPU USB Accelerator
By blakeblackshear
Frigate Integration
By blakeblackshear
By dermotduffy
Base frigate.yaml configuration file
homeassistant/frigate.yml
detectors:
  coral:
    type: edgetpu
    device: usb
mqtt:
  host: homeassistant.local
  port: 1883
  topic_prefix: frigate
  client_id: frigate
  user: #your mqtt user
  password: #your mqtt password
  stats_interval: 60
cameras:
  #simple camera example
  entrance:
📖 FFmpeg pressets here
#advanced camera example
livingroom:
    ffmpeg:
      output_args:
        record: preset-record-generic-audio-aac
      inputs:
        - path: rtsp://user:password@ip-hi-res-stream:port
          roles:
            - record
        - path: rtsp://user:password@ip-low-res-stream:port
          roles:
            - detect
    detect:
      height: 720
      fps: 5
    motion:
Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint pre-filled.
Blueprint
Blueprint
ffmpeg
inputs:
- path: rtsp://user:password@ip:port
roles: - record - detect
detect:
height: 720
fps: 5
record:
enabled: True
retain:
days: 7
mode: all
alerts:
retain:
days: 15
mode: motion
detections:
retain:
days: 10
mode: active_objects
review:
# Optional: alerts configuration
alerts:
# Optional: labels that qualify as an alert (default: shown below)
labels:
- person
- car
detections:
# Optional: labels that qualify as a detection (default: all labels that are tracked / listened to)
labels:
- dog
- cat
ffmpeg:
hwaccel_args: preset-rpi-64-h264
objects:
track:
- person
- car
- dog
- cat
filters:
person:
# Optional: minimum width*height of the bounding box for the detected object (default: 0)
min_area: 0
# Optional: maximum width*height of the bounding box for the detected object (default: 24000000)
max_area: 100000
# Optional: minimum score for the object to initiate tracking (default: shown below)
min_score: 0.5
# Optional: minimum decimal percentage for tracked object's computed score to be considered a true positive (default: shown below)
threshold: 0.7
mask:
- 1280,0,1280,49,1123,0
zones:
fixt_desk:
coordinates: 445,486,419,177,542,0,679,0,829,0,810,285,686,453,572,512
snapshots:
required_zones:
- fixt_desk
