Updated: Jun 13, 2024—4 min read
Easiest way to get your own Local AI: Ollama Docker Tutorial
Prerequisites Docker Installation (Linux/WSL)Activate GPU compatibilityInstallationOllama OnlyOpenWebUI OnlyOpenWebUI + OllamaHow to run itHow to update itOpen WebUIOllama LibraryOpen WebUI HubOllama Integrations
Ollama Icon
  • Windows 11 or Ubuntu 22.04 PC with at least 8GB of RAM (16GB recommended)
  • Nvidia GPU with Official Driver Installed (Optional, but recommended)
On Windows, you don't need to install any GPU driver on WSL, the official Nvidia Driver on Windows will take care of everything.
Based on the docker documentation [1, 2], you can install docker with the following commands:
Docker Installation Steps
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
sudo usermod -aG docker $USER
newgrp docker
##Test
docker run hello-world
Based on Nvidia documentation [1], you can install the Nvidia Container Toolkit with the following commands:
NVIDIA Container Toolkit Installation Steps
curl -fsSL https://nvidia.github.io/libnvidia-container/gpgkey | sudo gpg --dearmor -o /usr/share/keyrings/nvidia-container-toolkit-keyring.gpg \
  && curl -s -L https://nvidia.github.io/libnvidia-container/stable/deb/nvidia-container-toolkit.list | \
    sed 's#deb https://#deb [signed-by=/usr/share/keyrings/nvidia-container-toolkit-keyring.gpg] https://#g' | \
    sudo tee /etc/apt/sources.list.d/nvidia-container-toolkit.list
sudo apt-get update
sudo apt-get install -y nvidia-container-toolkit
sudo nvidia-ctk runtime configure --runtime=docker
sudo systemctl restart docker
##Test
docker run --gpus all nvidia/cuda:11.5.2-base-ubuntu20.04 nvidia-smi
Installation
Try any service without fear, you can always go back
You can select any of the following docker-compose files to install the services you need.
You can even select a different one in the future if you need more a less services. It will replace the current docker-compose.yaml file with the new one.
Then just use the corresponding command from the How to run it section, and docker will handle the rest.
Ollama Only
Ollama [CPU Only]
wget -O docker-compose.yaml  https://raw.githubusercontent.com/fixtse/blueprints/main/docker/docker-compose-ollama-cpu-only.yaml
Ollama [GPU]
wget -O docker-compose.yaml  https://raw.githubusercontent.com/fixtse/blueprints/main/docker/docker-compose-ollama-gpu.yaml
OpenWebUI Only
Open WebUI [CPU Only]
wget -O docker-compose.yaml  https://raw.githubusercontent.com/fixtse/blueprints/main/docker/docker-compose-open-webui-cpu-only.yaml
Open WebUI [GPU]
wget -O docker-compose.yaml  https://raw.githubusercontent.com/fixtse/blueprints/main/docker/docker-compose-open-webui-gpu.yaml
Open WebUI now includes some GPU accelerated features, like the document embembing, whisper TTS, and more.
OpenWebUI + Ollama
Ollama + Open WebUI [CPU Only]
wget -O docker-compose.yaml  https://raw.githubusercontent.com/fixtse/blueprints/main/docker/docker-compose-ollama.yaml
Ollama + Open WebUI [GPU]
wget -O docker-compose.yaml  https://raw.githubusercontent.com/fixtse/blueprints/main/docker/docker-compose-ollama-webui-gpu.yaml
How to run it
to run it
docker compose up -d
Use this if you want to remove old services
docker compose up -d --remove-orphans
Optional Activate WSL Server Mode.
To allow external connections to Ollama and OpenWebUI.
How to update it
to update it
docker compose pull
docker compose up --force-recreate -d
Open WebUI
By tjbck
Ollama Library
Open WebUI Hub
Ollama Integrations
