Updated: Oct 23, 2025—8 min read
Beginner DIY ESPHome mmWave Presence Sensor
PrerequisitesHLK-LD2450 Sensor SpecsfixtSE DIY Sensor CaseRemixesClip for TopMMwave Multi Sensor fixtSE LD2450How to wire it upESPHome FirmwareYAML FilesHow to create zonesHLKRadarToolHow to use it on your dashboardPlotly GraphHow to automate with it
Sensor
mmWave Sensor
Back
Esp32 housing
Inside
  • ESP32 30 PIN Development Board
    • Amazon: (3 pack)
    • Aliexpress: (USB C)
  • HLK-LD2450 mmWave Radar Sensor
    • Amazon: (HLK-LD2450 Kit)
    • Aliexpress: (HLK-LD2450 Kit)
      • Option 1
      • Option 2
Optional
  • Dupont Cable
    • Amazon: (Dupont Cable Female to female)
    • Aliexpress: (Dupont Cable Female to female)
  • USB C Cable
    • Amazon: (JSAUX USB C Cable [2-Pack 6.6ft])
    • Aliexpress: (USB C Cable)
  • 5v charger
    • Amazon: (2 Pack)
    • Aliexpress: (5v charger)
Back
  • Frequency: 24 GHz (ISM band)
  • Sensor Type: Millimeter wave radar
  • Detection Range: Up to 6 meters (approximately 8 meters in practical terms)
  • Module Size: Ultra-small, measuring 15mm x 44mm
  • Detection Angle: Âą60°
  • Pitch Angle: Âą35°
Additionally, the HLK-LD2450 sensor supports the following features:
  • Precise motion target localization and tracking: Distance, angle and speed.
  • Configurable Zones: It allows you to define up to 3 configurable zones for monitoring.
  • Multiple Connection Options: You can connect it using pin and socket interfaces.
  • Intelligent Algorithm Firmware: Utilizes FMCW waveforms and advanced signal processing technology.
I'll keep adding more sensors to this case, so you can use it for other projects as well. đŸ› ī¸
You can get it on:
Or order it from:
Save $5 on your first order using our link: https://pcbway.com/g/lHR6if
Remixes
Clip for Top
Clip
checkleylane made a clip to held the top of the original case
You can get it on:
Reimagined Case
F-Square made a new case for this project, with a lots of improvements:
  • Rearranged the sensors inside the case (now the case can look up, instead of down).
  • Added M3 Screws, so the body can be held in place easily.
You can get it on:
How to wire it up
Wire Up
ESP32 BoardHLK-LD2450
VIN5v
TX2RX
RX2TX
GNDGND
ESPHome Firmware
Updated firmware to ESPHome 2024.12.4
Added OTA support
YAML Files
How to create zones
HLKRadarTool
Plotly Graph
By dbuezas
Just replace mmwave_sensor with your sensor's name. Ej: mmwave_sensor_aac3 or mmwave_sensor_no_aac3 based on the firmware you flashed.
FirmwareSensor Name
With Bluetooth Proxymmwave_sensor
Without Bluetooth Proxymmwave_sensor_no
Custom Card
type: custom:plotly-graph
title: mmWave Radar Sensor
refresh_interval: 1
hours_to_show: current_day
layout:
  height: 230
  margin:
    l: 50
    r: 20
    t: 20
    b: 40
  showlegend: true
  xaxis:
    dtick: 100
    gridcolor: RGBA(200,200,200,0.15)
💡𐂷 Sensor Light
By Blacky
Documentation here
Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint pre-filled.
Sensor
Sensor
zerolinecolor
type: number
fixedrange: true
range:
- 400
- -400
yaxis:
dtick: 100
zerolinecolor: RGBA(200,200,200,0.15)
scaleanchor: x
scaleratio: 1
fixedrange: true
range:
- 600
- 0
entities:
- entity: ''
marker:
line:
shape: spline
width: 5
x:
- $ex hass.states["sensor.mmwave_sensor_target_1_x"].state /-10
'y':
- $ex hass.states["sensor.mmwave_sensor_target_1_y"].state /10
- entity: ''
marker:
line:
shape: spline
width: 5
x:
- $ex hass.states["sensor.mmwave_sensor_target_2_x"].state /-10
'y':
- $ex hass.states["sensor.mmwave_sensor_target_2_y"].state /10
- entity: ''
marker:
line:
shape: spline
width: 5
x:
- $ex hass.states["sensor.mmwave_sensor_target_3_x"].state /-10
'y':
- $ex hass.states["sensor.mmwave_sensor_target_3_y"].state /10
- entity: ''
mode: lines
fill: toself
fillcolor: RGBA(20,200,0,0.1)
line:
color: RGBA(20,200,0,0.2)
shape: line
width: 2
x:
- $ex hass.states["number.mmwave_sensor_zone_1_x1"].state /-10
- $ex hass.states["number.mmwave_sensor_zone_1_x2"].state /-10
'y':
- $ex hass.states["number.mmwave_sensor_zone_1_y1"].state /10
- $ex hass.states["number.mmwave_sensor_zone_1_y2"].state /10
- entity: ''
mode: lines
fill: toself
fillcolor: RGBA(200,0,255,0.1)
line:
color: RGBA(200,0,255,0.2)
shape: line
width: 2
x:
- $ex hass.states["number.mmwave_sensor_zone_2_x1"].state /-10
- $ex hass.states["number.mmwave_sensor_zone_2_x2"].state /-10
'y':
- $ex hass.states["number.mmwave_sensor_zone_2_y1"].state /10
- $ex hass.states["number.mmwave_sensor_zone_2_y2"].state /10
- entity: ''
mode: lines
fill: toself
fillcolor: RGBA(200,120,55,0.1)
line:
color: RGBA(200,120,55,0.2)
shape: line
width: 2
x:
- $ex hass.states["number.mmwave_sensor_zone_3_x1"].state /-10
- $ex hass.states["number.mmwave_sensor_zone_3_x2"].state /-10
'y':
- $ex hass.states["number.mmwave_sensor_zone_3_y1"].state /10
- $ex hass.states["number.mmwave_sensor_zone_3_y2"].state /10
- entity: ''
mode: lines
fill: tonexty
fillcolor: rgba(168, 216, 234, 0.15)
line:
shape: line
width: 1
dash: dot
x:
- 0
- $ex 600 * Math.sin((2 * Math.PI)/360 * 60)
- 450
- 400
- 300
- 200
- 100
- 0
- -100
- -200
- -300
- -400
- -450
- $ex -600 * Math.sin((2 * Math.PI)/360 * 60)
- 0
'y':
- 0
- $ex 600 * Math.cos((2 * Math.PI)/360 * 60)
- $ex Math.sqrt( 600**2 - 450**2 )
- $ex Math.sqrt( 600**2 - 400**2 )
- $ex Math.sqrt( 600**2 - 300**2 )
- $ex Math.sqrt( 600**2 - 200**2 )
- $ex Math.sqrt( 600**2 - 100**2 )
- 600
- 0
raw_plotly_config: true
Shop Content
YAML
TinkererFree
Member Banner
Available in our Store! Or, join the Tinkerer or Automation Hero tier to access our latest Shop Content for FREE!
  • Your support is invaluable in allowing us to continue creating the tutorials you like 😁🏠🎉
  • Click on the Patreon button below to become a member, and then log in with your Patreon Account on our website.
FIRMWARE
This firmware is free for all our YouTube subscribers!
