Updated: Jan 20, 2025—4 min read
Ultimate ESPHome DIY Smart Sensor
PrerequisitesfixtSE DIY Sensor CaseRemixesClip for TopMMwave Multi Sensor fixtSE LD2450How to wire it upESPHome FirmwareYAML Files
Sensor
mmWave Sensor
Side a
Side b
Inside
ESP32
HLK-LD2450 Presence Sensor
BH1750 Light Sensor
AHT20 BMP280 Temperature Humidity and Pressure Sensor
BH1750 Sensor
  • BH1750 Light Sensor
    • Amazon: (3 pack)(6 pack)
    • Aliexpress: (BH1750)
AHT20_BMP28 Sensor
  • AHT20 BMP280 Temperature Humidity and Pressure Sensor
    • Amazon: (6 pack) (2 pack)
    • Aliexpress: (AHT20 BMP280)
Dupont cable
  • Dupont Cable
    • Amazon: (Dupont Cable 120 PCS Assorted)
    • Aliexpress: (Dupont Cable Male to Male and Male to Female)
Termoretractil Heat shrink tube
  • Termoretractil Heat shrink tube
    • Amazon: (Heat Shrink Tube)
    • Aliexpress: (Heat Shrink Tube)
You can get it on:
Or order it from:
Save $5 on your first order using our link: https://pcbway.com/g/lHR6if
Remixes
Clip for Top
Clip
checkleylane made a clip to held the top of the original case
You can get it on:
Reimagined Case
F-Square made a new case for this project, with a lots of improvements:
  • Rearranged the sensors inside the case (now the case can look up, instead of down).
  • Added M3 Screws, so the body can be held in place easily.
You can get it on:
How to wire it up
Wire Up
ESP32 BoardBH1750AHT20 BMP280
3v3VCCVDD
GNDGNDGND
D22SCLSCL
D21SDASDA
ESPHome Firmware
Updated firmware to ESPHome 2024.12.4
Added OTA support
FirmwareSensor Name
With Bluetooth Proxyuesp-sensor
Without Bluetooth Proxyuesp-sensor-no
YAML Files
Sensor
Sensor
Shop Content
YAML
Now available exclusively in our store.
Get instant access by purchasing using the button above.
Already own a copy? Log in with your email account to access your unlocked items from our store.
FIRMWARE
This firmware is free for all our YouTube subscribers!
