fixt/home-3b-v3:TAG| Name | TAG | Bits | Size | Max RAM required | Use Case |
| Home-3B-v3.q2_k.gguf | Q2_K | 2 | 1.08 GB | 3.50 GB | smallest, significant quality loss - not recommended for most purposes |
| Home-3B-v3.q3_k_m.gguf | Q3_K_M | 3 | 1.39 GB | 3.89 GB | very small, high quality loss |
| Home-3B-v3.q4_k_m.gguf | Q4_K_M | 4 | 1.71 GB | 4.21 GB | medium, balanced quality - recommended |
| Home-3B-v3.q5_k_m.gguf | Q5_K_M | 5 | 1.99 GB |
fixt/home-3b-v2:TAG| Name | TAG | Bits | Size | Max RAM required | Use Case |
| home-3b-v2.q2_k.gguf | q2_k | 2 | 1.11 GB | 3.67 GB | smallest, significant quality loss - not recommended for most purposes |
| home-3b-v2.q3_k_m.gguf | q3_k_m | 3 | 1.43 GB | 3.98 GB | very small, high quality loss |
| home-3b-v2.q4_k_m.gguf | q4_k_m |
WSLPorts is a PowerShell script that allows you to easily redirect and open ports in the Windows Firewall for your WSL Services.
It also prevents Windows from shuttting down WSL so you don't have to keep a Terminal Open C:\WSLPorts\WSLPorts.ps1Automate Script Execution at Logon
$a = New-ScheduledTaskAction -Execute "powershell.exe" -Argument "-ExecutionPolicy Bypass -WindowStyle Hidden -File `"C:\WSLPorts\WSLPorts.ps1`" "
$t = New-ScheduledTaskTrigger -AtLogon
$s = New-ScheduledTaskSettingsSet -AllowStartIfOnBatteries -DontStopIfGoingOnBatteries
$p = New-ScheduledTaskPrincipal -GroupId "BUILTIN\Administrators" -RunLevel Highest
Register-ScheduledTask -TaskName "WSLPorts" -Action $a -Trigger $t -Settings $s -Principal $pto update it
docker compose pull
docker compose up --force-recreate -d| 4.49 GB |
| large, very low quality loss - recommended |
| Home-3B-v3.q8_0.gguf | Q8_0 | 8 | 2.97 GB | 5.47 GB | very large, extremely low quality loss - not recommended |
| 4 |
| 1.74 GB |
| 4.29 GB |
| home-3b-v2.q5_k_m.gguf | q5_k_m | 5 | 2.00 GB | 4.57 GB | large, very low quality loss - recommended |
| home-3b-v2.q8_0.gguf | q8_0 | 8 | 2.96 GB | 5.46 GB | very large, extremely low quality loss - not recommended |
