Fixtโ€ขยฉ 2026
Updated: Apr 20, 2024โ€”3 min read
The All-in-one Smart Home Gateway - SMLIGHT SLZB-06
SpecsWhere to buy them?DocumentationDefault URLZHA IntegrationHow to add Zigbee Devices with ZHAZigbee2MQTT Add-onGiveaway Winners
Zigbee
Thread
Matter
If you like my work, please consider supporting me on Ko-fi! โ˜•๐ŸŽ‰
โ† Back to the blog
SMLight SLZB-06
Specs
DescriptionSLZB-06SLZB-06MSLZB-06p7SLZB-06p10
Release Year2022202320242024
Zigbee SoCะกะก2652ะ EFR32MG21CC2652P7CC2674P10
Core SoCESP32ESP32ESP32ESP32
Matter SupportYesYesYesYes
EthernetYesYesYesYes
PoEYesYesYesYes
Support Open FirmwareYesYesYesYes
Support ESPHome FirmwareYesYesYesYes
Where to buy them?
Using the affiliate links below helps support the channel and all the content I create ๐ŸŽ‰๐Ÿ™Œ
  • SMLIGHT SLZB-06
    • Amazon: (SLZB-06)
    • Aliexpress:
      • Option 1
      • Option 2
Optional
  • POE injector 48v 24w
    • Amazon: (POE injector 48v 24w)
    • Aliexpress: (POE injector 48v 24w)
You can access the oficial Documentation here and the GitHub repository here
Default URL
  • Wifi Mode URL: http://192.168.1.1
  • SLZB-06
  • SLZB-06M
  • SLZB-06p7
  • SLZB-06p10
ZHA Integration
Open your Home Assistant instance and add a Zigbee device to your instance.
You can use this button to be redirected to you Home Assistant instance to add the device to your Zigbee network.
Zigbee2MQTT Add-on
Note: This is an alternative to the ZHA integration. You can't use both at the same time.
Settings > Add-ons > Zigbee2MQTT > Configuration > Serial
port: tcp://slzb-06.local:6638
baudrate: 115200
adapter: zstack
port: tcp://slzb-06m.local:6638
baudrate: 115200
adapter: zstack
port: tcp://slzb-06p7.local:6638
baudrate: 115200
adapter: zstack
port: tcp://slzb-06p10.local:6638
baudrate: 115200
adapter: zstack
Mosquitto broker Add-On
Settings > Add-ons > Zigbee2MQTT > Configuration > MQTT
server: mqtt://core-mosquitto:1883
user: your_homeassistant_user
password: your_homeassistant_password
Giveaway Winners
Zigbee
Thread
Matter
Zigbee
Thread
Matter
