Published: Oct 26, 2025—1 min read
Sonoff Dongle-Max and Dongle Plus MG24 Zigbee 3.0 USB Adapter Review & Setup
SONOFF Dongle Plus MG24SONOFF Dongle MaxConfigure ZHA IntegrationZigbee2MQTT Add-on
Zigbee Coordinator
SoCEFR32MG24
Flash/RAM1536KB Flash, 256KB RAM
ConnectivityUSB-A
USB ControllerCP2102(N) USB-Serial
AntennaSingle adjustable (Max 4.5 dBi)
Range200m line of sight
ProtocolZigbee 3.0, Thread
ManagementSONOFF Flasher tool
Alternative links:
ITEAD Store
SONOFF Dongle Max
Zigbee Coordinator
SONOFF Dongle Max
Primary SoCEFR32MG24
Secondary SoCESP32D0WDR2
ConnectivityEthernet (PoE), WiFi 2.4GHz, USB-C
AntennasDual adjustable (5 dBi each)
ManagementWeb-based console
FirmwareRemote web-based updates
RangeEnhanced practical range
Using the affiliate links helps support the channel and all the content I create 🎉🙌
Zigbee2MQTT Add-on
Note: This is an alternative to the ZHA integration. You can't use both at the same time.
