Published: Oct 28, 2023—2 min read
Enabling Thread, Zigbee and Matter support on the Sonoff ZBDongle-E
PrerequisitesFlash FirmwareInstall Silicon Labs Multiprotocol Add-onConfigure ZHA IntegrationZigbee2MQTT Add-onConfigure Thread IntegrationAdd Matter Devices
Zigbee
Thread
Matter
Sonoff ZBDongle-E
  • ZBDongle-E
Flash Firmware
Go to this web to install the MultiPAN RCP firmware on your ZBDongle-E. Created by darkxst
Be sure to stop the ZHA integration or ZigbeeToMQTT before flashing the firmware.
Zigbee2MQTT Add-on
Note: This is an alternative to the ZHA integration. You can't use both at the same time.
Settings > Add-ons > Zigbee2MQTT > Configuration > Serial
port: tcp://core-silabs-multiprotocol:9999
adapter: ezsp
Add Matter Devices
Zigbee
Thread
Matter
Zigbee
Thread
Matter
