Published: May 18, 2024—1 min read
Free Voice Assistant TTS & STT in Home Assistant using Azure
Azure AccountAdd-onsWyoming Microsoft TTSWyoming Microsoft STTOpenWakeWordWyoming IntegrationConfigure Assistant
TTS & SST Cloud
Azure Account
You can check the list of free available services here
Create an account on https://portal.azure.com/
Create a speech service
Add-ons
By hugobloem
By hugobloem
OpenWakeWord
Wyoming Integration
