Published: Aug 23, 2025—2 min read
I Cloned My Own Voice for My Smart Home!
Hardware RequirementsRecommended GPUsNvidia RTX 3060 12GBNvidia RTX 4060 Ti 16GBChatterbox TTS APIOpenAI TTS Speech IntegrationInstall HACSInstall IntegrationConfigurationConfigure AssistantConfigure ESPHome Device
Chatterbox Logo
TypevRAMRAM
GPU6 GB8 GB
CPU-16 GB
Recommended GPUs
Nvidia Chip
The GPU recommendations are not only for running Chatterbox, but also for running local LLMs to complement your local assistant
Chatterbox TTS API
By Travisvn
Clone Repository
git clone https://github.com/travisvn/chatterbox-tts-api
cd chatterbox-tts-api
cp .env.example.docker .env
CPU Only
docker compose -f docker/docker-compose.yml --profile frontend up -d
Nvidia GPU
docker compose -f docker/docker-compose.uv.gpu.yml --profile frontend up -d
Then go to http://localhost:4321
By sfortis
Install HACS
You can find the documentation here
Install Integration
API Endpoint
http://localhost:4123/v1/audio/speech
