Published: May 4, 2024—2 min read
Use WLED Light Effects in ESPHome
Example YAML device configurationVisual Studio Code Add-onAdd DDP to your WLED configurationSet DDP effect in ESPHome after Network is connectedESPHomeWLED Configuration
WLED
Sound Reactive Ambient
homeassistant/esphome/esphome_wled_effects.yaml
esphome:
  friendly_name: ESPHome Wled Effects
  project:
    version: "1.0"
  min_version: 2023.11.1
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
web_server:
  port: 80
# Enable Home Assistant API
api:
ota:
improv_serial:
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  on_connect:
    - delay: 5s # Gives time for improv results to be transmitted
  # Enable fallback hotspot (captive portal) in case wifi connection fails
  ap:
    ssid: "esphome_wled_effects"
captive_portal:
button:
  - platform: factory_reset
light:
  - platform: neopixelbus
    variant: WS2812
    pin: GPIO16
    default_transition_length: 250ms
    type: grb
    num_leds: 142
    effects:
      - pulse:
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 80%
You can check the documentation here
External DDP Component
external_components:
  - source:
      type: git
      url: https://github.com/KaufHA/common
    components: [ ddp ]
    refresh: always
ddp:
light:
    effects:
      - addressable_ddp:
WLED Configuration
WLED
WLED
SCRIPT
This script is free for all our YouTube subscribers!
