Published: May 4, 2023β€”2 min read
Automating Your Windows PC using Home Assistant and HASS Agent
Download linksMQTT installation (Mosquitto Broker)HASS Agent configurationGenerate API TokenCommands configurationHASS Agent custom integrationMedia Player UsageNotifications Usage
Download links
HASS Agent: https://github.com/LAB02-Research/HASS.Agent/releases
HASS Agent Installer
First, go to setting in the Home Assistant menu.
i1
Then click on addons
i2
Click on the add-on store icon in the bottom right corner
i3
Search for the Mosquitto broker add-on and click on it, then click on install
i4
i5
After it's finished, click on start
i6
Now we are going to configure the MQTT integration in home assistant, for this, go to setting in the Home Assistant menu and then click on Devices & Services
i7
Click on the Configure button for the MQTT integration and then click on Submit
i8
i9
if everything went well, you should see the following message
i10
if not, reboot home assistant and try again
For the most updated configuration, please refer to the official HASS.Agent documentation: https://hassagent.readthedocs.io/en/latest/configuration/
Generate API Token
Go to your profile in Home Assistant (bottom left corner, bellow notifications).
Scroll down to the end of the page and click on Create Token
i11
Give it a name and copy it to the HASS.Agent configuration
https://hassagent.readthedocs.io/en/latest/commands/command-basics/
https://hassagent.readthedocs.io/en/latest/integration/installation/
Media Player Usage
https://hassagent.readthedocs.io/en/latest/mediaplayer/mediaplayer-usage-and-examples/
Notifications Usage
https://hassagent.readthedocs.io/en/latest/notifications/notification-usage-and-examples/
