Published: Jul 30, 2023—3 min read
My First Home Assistant Card 🎉: O365 Card 🗒️
InstallationAdd more functionalityCreate new task from the dashboardNew Task Dashboard CardAnswer Last Teams Message AutomationAnswer Last Teams Message Dashboard Card
Microsoft-365
Automation
Microsoft-365
Automation
Microsoft-365
Automation
Installation
O365 Card Config
This is a Custom Card to show information from your O365 sensors into the home assistant dashboard.
The intent is to create a simple and easy-to-use card to show the sensor's information in the dashboard.
Once installed can be added from the Dashboard Panel, just search for O365 Card, works with the Lovelace Config Editor.
Supported Types
Mail
To Do
Teams
Open your Home Assistant instance and show your helper entities.
You can use this button to go to the helpers page. There create a new input_text (Text) and name it as you want.
To Do
config/automations.yaml
alias: Create new task office 365 list
description: ""
trigger:
  - platform: state
    entity_id:
      - input_text.o365_card_task_input #Change this to your input_text
condition:
  - condition: template
    value_template: '{{ (states.input_text.o365_card_task_input.state | length) > 0 }}' #Change this to your input_text
    enabled: true
action:
  - service: o365.new_task
    data:
Custom Card
type: vertical-stack
cards:
  - type: custom:o365-card
    entity: sensor.create_office365_card_fixt #Change this to your tasks sensor
    max_items: 0
    only_overdue: false
  - type: entities
    entities:
      - entity: input_text.o365_card_task_input #Change this to your input_text
Teams
alias: Send Teams Chat Message
description: ""
trigger:
  - platform: state
    entity_id:
      - input_text.o365_card_chat_input #Change this to your input_text
condition:
    value_template: '{{ (states.input_text.o365_card_chat_input.state | length) > 0 }}' #Change this to your input_text
    enabled: true
action:
  - service: o365.send_chat_message
    data:
Custom Card
cards:
    entity: sensor.fixt_chat #Change this to your chat sensor
    max_items: 0
    only_overdue: false
  - type: entities
    entities:
      - entity: input_text.o365_card_chat_input #Change this to your input_text
subject
{{ states.input_text.o365_card_task_input.state }}
target:
entity_id: sensor.create_office365_card_fixt #Change this to your tasks sensor
- service: input_text.set_value
data:
value: ''
target:
entity_id: input_text.o365_card_task_input #Change this to your input_text
- service: homeassistant.update_entity
data: {}
target:
mode: single
chat_id: '{{ states.sensor.fixt_chat.attributes.chat_id }}' #Change this to your chat sensor
message: '{{ states.input_text.o365_card_chat_input.state }}' #Change this to your input_text
target:
entity_id: sensor.fixt_chat #Change this to your chat sensor
data:
value: ''
target:
entity_id: input_text.o365_card_chat_input #Change this to your input_text
mode: single
CARD
This card is free for all our YouTube subscribers!
