Published: Nov 8, 2024—2 min read
Make Anything Smart With the SonOff ZBMINI EXTREME
SpecsDocumentationWhere to buy it?L2 (No neutral wire required)R2 (Neutral wire required)Phase Detector
SONOFF ZBMINIR2
Specs
DescriptionL2R2
Neutral WireNoYes
Max Current10A10A
Input/Output100-240V100-240V
ProtocolZigbee 3.0Zigbee 3.0
RoleEnd DeviceRouter
Sub-devices-64
Turbo ModeNoYes
OTAYesYes
You can access the oficial Documentation for the L2 and R2 to check the wiring Instructions
Where to buy it?
  • ITEAD Store
  • ITEAD Store
Use Coupon Code: FIXTSONOFF for 10% off on the ITEAD Store
Phase Detector
Phase Detector
