Updated: Mar 1, 2024—2 min read
Sentinel Sight: AI Vigilance with Gemini Vision and Home Assistant
Install Integration version with Gemini Vision SupportGoogle AI API KeyGoogle IA Conversation IntegrationSentinel Sight: BlueprintInstall Visual Studio Code Add-on
New Microsoft 365 integrations for Home AssistantNew Microsoft 365 integrations for Home Assistant
Blueprint
Sentinel Sight: Unleash the Full Power of AI Vigilance with Gemini Vision and Home Assistant
Download if from here
Home Assistant version 2024.2 is out, and it brings support for Gemini Vision built in.
You can safely remove the Custom Integration files
Google AI API Key
First you need to generate an API key to use with the integration, you can generate yours here.
Gemini Vision is running on Google Cloud using the Vertex AI Conversation API
Is free to use for now, but Google may enforce rate limits during this period.
This integration allows you to use the Google AI Conversation API to generate text. You can use this to generate personalized messages for automations and scripts.
You can find the documentation here.
New Sentinel Sight v2 available here
AI-Powered Vigilance with Gemini Vision
You can buy the blueprint and support the channel by clicking the button
Blueprint
Blueprint
